rockbox question - totally clueless
0 Members and 1 Guest are viewing this topic. Read 1844 times.
lousyreeds1
« on: 26 Dec 2006, 04:14 pm »
Hi folks,
I ordered an iMod from Vinnie (exciting!), and I'm currently going through the painful process of ripping all my CDs onto my Mac.  I'm intrigued by the rockbox firware for two reasons:
first, rumor has it FLAC sounds a bit better than Apple Lossless.
second, I reeeaaallly want gapless playback.
The question: if I've already ripped a lot of my music in Apple lossless, do I have to go back and rerip it in FLAC?  I'm a little confused here.  Does rockbox affect the iTunes software itself, or just the iPod?
Oliver
Vinnie R.
    • http://www.vinnierossi.com
Re: rockbox question - totally clueless
« Reply #1 on: 27 Dec 2006, 03:39 pm »
Hi Oliver,
I'm not totally convinced that I can hear a difference between FLAC and Apple Lossless.  They are both lossless, but perhaps there is something going on in SW that may explain why people hear a difference (iPod's stock SW vs Rockbox).
RockBox is compatible with Apple Lossless, FLAC, and many others.  If you want your files to be converted to FLAC, you have to convert them.  I'm not sure if there is automated SW out there that will convert from Apple Lossless to FLAC for you..
Itunes is not changed, but the SW on your iPod is changed.  After RockBox, you will essentially treat your iPod like a USB hard drive.  You make a music folder and copy and paste your music files into it.  I don't think you'll be using iTunes when you use Rockbox, but I may be wrong.
There have been Rockbox updates since I tried it a while back, so it is best to get all the gory details here:
http://www.rockbox.org/
and this might be useful:
http://en.wikipedia.org/wiki/Rockbox
Best regards,
Vinnie
PS: There are tons of Rockbox topics posted on www.headfi.com if you do a search there.  Those guys are really into it!
lousyreeds1
« Reply #2 on: 28 Dec 2006, 06:21 pm »
Hi Vinnie,
Thanks, helpful as always!  I'll check out headfi.org.  Can't wait to get my new iMod!
Happy holidays,
Oliver
