0 Members and 1 Guest are viewing this topic. Read 8777 times.
Those voltage regulators don't supply enough current. I believe you need 1A minimum for the squeezeboxes. Their diode bridges are constructed from the surface mount diodes they sell (you can get the same thing from digikey, for example). They just string several together to increase the current delivery ability. I'm not certain of the efficacy of using the smaller diodes strung together.
Hey! Well, I don't know about those stuffs you mentioned from RAM. They look interesting. But here is something you might want to consider for your Squeezebox. http://www.welbornelabs.com/squeeze.htm Anyway, have fun and let us know how it turn out. Take care,Buddy
Jim,A Hammond 185C12 would work nicely. Mouser has them in stock for $16.21ea.: http://www.mouser.com/search/refine.aspx?Ntt=546-185C12%09This is 6.3V@4A, just fine for a 5V regulated supply for your SB. You will have about 9VDC before the regulator, so the regulator only has to drop 4 volts. This transformer will work for either 115 or 230V. You don't need 4 amps but the extra capacity won't hurt and the transformer should run a little cooler. The SB draws just over 1A at full brightness when wireless is enabled. Use at least a 1.5A capable regulator. The Linear Technology regulators are very nice. Have a look at the LT1085, it's capable of 3A and works very well. http://www.linear.com/pc/productDetail.do?navId=H0,C1,C1003,C1040,C1055,P1283Don't forget to properly heat sink the regulator.
Hi Jim, you could run two LT regulators in series but you would of course need to set the output voltage of the first regulator at least 2.5 volts higher than the output voltage of the second regulator. So for the first regulator you would want about 10VDC on the input and 7.5VDC on the output. A little more wouldn't hurt. The ALWSR is basically a very nicely done Jung Super Regulator. Assuming it can provide the current required I suspect it will be hard to do better without spending a lot of money. Hugh Dean is has an offering that is supposed to be stellar but it's far more expensive. mike
I don't think you're going to get 1.5a, more like 200ma or so with the Jung SR's
Take a look at the Linear Technology application note for the LT108x series (thanks Mike). That is the simple circuit I built.
Do we need super regulation for the SB though? I forget what all our sagely Occam had to say on the matter (there is a post here that I started about SB mods), but I do believe the opamps and dac chip have on-board regulation. Does this mean that the extra regulation would be moot? Not sure.
