Interesting System Set-UP
0 Members and 1 Guest are viewing this topic. Read 886 times.
Rocket_Ronny
    • ScriptureSongs.com
« on: 22 Dec 2006, 06:55 pm »
Howdy all:
I thought I would post this as you might find this an interesting room set-up, being a little off the beaten path.
http://www.audiocircle.com/index.php?topic=31630.80
I think this delivers top shelf sound for reasonable $$$.
Have a great holiday season.  :wink:
Rocket_Ronny
« Last Edit: 22 Dec 2006, 08:13 pm by Rocket_Ronny »
ctviggen
Re: Interesting System Set-UP
« Reply #1 on: 22 Dec 2006, 07:03 pm »
The imaging isn't shifted to the left?  It seems as if the back wave from the right speaker would simply travel down the hall.  You don't have to worry about damping the front wall, though, as there isn't any.
Rocket_Ronny
« Reply #2 on: 22 Dec 2006, 08:19 pm »
Bob:
No, the imaging is not shifted to the left. Even if it was, I could simply adjust for it in the Metric Halo console. The imaging is fantastic. The kind you would never get if there was not the hole in the wall. Space man, it's the final frontier in audio.
The real issue in that room though is the bass gain on the left due to the corner. I will address this later.
Wish you could have a listen.  8)
Rocket_Ronny
