Daygloworange....
0 Members and 2 Guests are viewing this topic. Read 1912 times.
Marbles
Daygloworange....
« on: 20 Dec 2006, 05:37 pm »
I noticed in your gallery you have some DIY diffusers.
These look nice, can you tell us how you made these and about how much they cost?
TIA
Daygloworange
  • www.customconcepts.ca
Re: Daygloworange....
« Reply #1 on: 20 Dec 2006, 06:06 pm »
They are made from Owens Corning extruded polystyrene insulation. The triangle shapes are cut from long strips at angles. The skyline profiles are cut using the hotwire method, then stacked side by side to form a panel. Both the skyline type and triangle shape are then glued to a 1/2" polystyrene sheet, then glued to a 1/2" sheet of semi rigid fibreboard. Then painted with latex paint. And they really work well. I made about 36 panels total.
I'm experimenting with a new material from Dow chemical called "Quash".  It's an expanded polypropylene foam. A colleague of mine is in acoustics, and is a distributor for it here. He dropped off a skid full of 2" thick sheets. I'm going to try using it in some experimental bass traps. The stuff is cool. It's water proof, mold proof, and isn't made of fibres.
Another colleague of mine owns an acoustics consultation firm. He's going to help me design some bass traps. It should be cool. These guys are heavy duty . They design tuned mass dampers for buildings and all kinds of other things.
Sometimes, it's not what you know. It's who you know. :wink:
I'll post more about that when I get around to it.
Cheers
« Last Edit: 21 Dec 2006, 02:55 am by Daygloworange »
Canyoneagle
« Reply #2 on: 20 Dec 2006, 06:18 pm »
Those look awesome!
Is the foam pretty easy to work with (i.e. clean cuts, etc)?
I'm curious about your bass traps, so keep us all posted with developments.
Warmly,
Michael
Daygloworange
« Reply #3 on: 20 Dec 2006, 06:31 pm »
Thanks for the encouragement guys. The diffusors were easier, in that plenty of info exists on the web, and the theory and implementation is easy.
I'm also going to do some well type, Schroeder based diffusors.
Bass traps are a little more difficult. I want to do a membrane type, rather than just a rigid fiberglass panel. So I'm going to bend some ears on the topic, and see if I can build some really, really effective ones that aren't huge. And see about how broadband I can get it. In short, there is a lot I need to learn about it before I attempt it. I need to do some homework.
I hate doing anything half baked, then only to find out that if I did a bit more research, I could have done it better.
No. Definitely not. It galls and wants to attach itself to the blade as it's being cut. It also oscillates and wanders as it's being cut, it can be quite dangerous. We have a saw with a sliding table that feeds into the saw, so the operators hands are nowhere near the blade. I wouldn't recommend cutting strips on a small table saw. Too dangerous. If you don't have extremely powerful dust collection, forget it. The chips fly everywhere, and due to static, cling to everything, and I mean everything.( clothes, the floor, machinery, your hair, the foam itself). You can't blow it off, the static charge is very strong.
I will update you guys on my bass trap findings.
Cheers
« Last Edit: 13 Feb 2007, 02:46 pm by Daygloworange »
Canyoneagle
« Reply #4 on: 20 Dec 2006, 07:29 pm »
Thanks for the info.
I'll keep my eyes peeled for updates.
Warmly,
Michael
