0 Members and 1 Guest are viewing this topic. Read 7766 times.
Hi Buddy,You can buy Buna-N O-ring material by the foot at many industrial supply outlets, or online at McMaster-Carr etc.Either 2mm or 1/16" (.070) diameter will work as a turntable belt. I'm pretty sure this is the same material as the original Rega P2 belt, and possibly many others. If I'm wrong on this, someone please correct me.Use a razor blade to spice the ends and use Superglue/Krazyglue (cyanoacrylate) to attach the ends. Voila, instant belt.Regards,Jeff
Hey! Thanks guys But still I want to know if any of you guys here have turn TT like JA Michell, Clearaudio, VPI and etc... I know that they use round belt so I wonder about the length and diameter of those belts. If not Jeff... I think I will have to get those o-ring as you mentioned. Pretty good idea. But wonder how can I glue without making a bump on the belt Take care,Buddy
Quote from: SET Man on 24 Dec 2006, 07:14 pmHey! Thanks guys But still I want to know if any of you guys here have turn TT like JA Michell, Clearaudio, VPI and etc... I know that they use round belt so I wonder about the length and diameter of those belts. If not Jeff... I think I will have to get those o-ring as you mentioned. Pretty good idea. But wonder how can I glue without making a bump on the belt Take care,Buddy my TT uses sewing thread for a drive belt, and it's on it's second one in five years.gary
Hey! Wonder if you vinyl people here could help me with this? I'm looking for a specific turntable belt. I need a longer version of round belt for Rega Planar 2. The Planar use round belt approximately 2mm in diameter. I would need something around 30" in length. If that doesn't exist than I'm sure that there are TTs out there that use round belt like VPI, Clearaudio, JA Michell and etc. If anyone here own a TT with round belt like those mentioned could please let me know what is the diameter and length of your TT belt? Any help would be greatly appreciated.Take care,Buddy
Why are you trying to use a round belt overt the standard Rega belt anyway?
Try these guys.http://turntablebasics.com/beltmodels.html#o-ringThey can also have belts made to spec as well.
Hi Buddy,I say go for it! You can always go back to the original setup if things don't work out. I still maintain that you could make your own belt. Just google "o-ring splicing" and you will see what the kits look like and how to cut the o-ring material to get nice square ends, before gluing.I had a P2 for many years, but never tried to mod it. I think I went thru 4 carts with that TT.Best of luck,Jeff
