FS: Blue Circle BC202 hybrid stereo amp demo unit
0 Members and 1 Guest are viewing this topic. Read 1806 times.
PhilNYC
« on: 19 Dec 2006, 01:07 pm »
I'm putting up the following for sale here on AC; will place up on Audiogon on January 2 if they aren't sold here:
Blue Circle BC202 Hybrid Stereo Amplifier (w/BC62 power cord)
Current retail:  $5795
For Sale price: $4000
This unit is about 2 years old.  There is one year left on the manufacturer's warranty.  It is in perfect working condition, with minor cosmetic blemishes (paintable!).  Tubes were replaced earlier this year.
Original box included with "new outer box".  Manual available direct from Blue Circle.
PM or email me ([email protected]) if interested...
-125 watts into 8 ohms and 200 watts into 4 ohms per channel output
-True balanced from input to output with both positive and negative binding posts being "hot" with signal.
-DC coupled output stage
-Blue Circle "Blue Puck Cap" used in power supply filtering, both in output stage and B+ supply
-Local "on board" filtering cap located at less than an inch away from the actual output devices for better transient response.
-All control circuits are done in analog domain. Therefore, no digital clock to contaminate the analog signal integrity. It’s an analog amp after all.
-Heavy gauge power supply ground return path for both tube and output stages with the exact same reference for both tube and output stages to yield the best matching performance.
-20Amp Neutrik "Power Con" power connector with 6ft BC62 power cord
-All internal ac power is controlled by 30A ac power relays for shortest ac power run inside the chassis.
-600VA power transformer supply for output stage only
-Three separate power transformers for output stage, tube input stage and controls
-Over 200,000uF in power supply filtering.
-Power HexFred rectifier in both output stage and B+ supply
-12Ga steel chassis for mechanical integrity
-Two pairs of binding posts per channel for shot gun biwire
-RCA and XLR input
-Ground lift switch to eliminate ground loops. This switch will only lift the signal ground, the chassis is connected to earth ground at all times for safety.
-Dimensions: 15.5" wide x 9.5" high x 20.5" deep
-Weight: 70lbs
« Last Edit: 19 Dec 2006, 01:45 pm by PhilNYC »
PhilNYC
Re: FS: Blue Circle BC202 hybrid stereo amp demo unit
« Reply #1 on: 28 Dec 2006, 03:15 pm »
Thought I'd bump this up...it's going on Audiogon Monday....
