Stuck Like Chuck
0 Members and 1 Guest are viewing this topic. Read 1258 times.
drake
Stuck Like Chuck
« on: 19 Dec 2006, 06:53 am »
Stuck like chuck? I like the idea of a planar speaker in a line array setup but there does not seem to be a way to DIY such a speaker. Unless I rob the planar’s out of some monsoon computer speakers.   They look like the same planer VMPS used in their RM 40’s. I could also go the RAW route with their ribbon tweeter.
Anyone know how to DIY a speaker that has a midrange as good as a planar and the snap of a compression horn????
Matt
pjchappy
Re: Stuck Like Chuck
« Reply #1 on: 19 Dec 2006, 09:35 am »
drake
« Reply #2 on: 20 Dec 2006, 06:43 am »
Using those in a OB-7 like setup might be the sound I am looking for.
Thanks for the help!
Matt
