Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
Bugle Battery Power MOd?
0 Members and 1 Guest are viewing this topic. Read 1972 times.
dimora
Newbie
19 Dec 2006, 02:23 am »
Can I mod my Hagerman Bugle to run on two banks of 6 D cells in series (9 volts per channel) instead of going the 9 volt battery route? I jsut want to make sure I won't fry anything.
hagtech
Facilitator
Re: Bugle Battery Power MOd?
19 Dec 2006, 03:02 am »
Yup. You can even run more batteries for higher voltage. This is exactly what I think is in the PhD phonostage.
jh
dimora
Newbie
Reply #2 on:
19 Dec 2006, 04:31 pm »
Thanks Jim!
What kind of max voltage would you recommend for optimum performance - 12 volts or so (8 D cells per channel?)
Best regards,
Shane
analog97
Reply #3 on:
19 Dec 2006, 06:39 pm »
Shane,
Kindly post a picture of this when done. I am interested in trying to source the battery holders as well as seeing how this would be wired up. Thanks in advance.
hagtech
Facilitator
Reply #4 on:
19 Dec 2006, 07:05 pm »
8 cells is fine. Automotive standard (maybe that's the wrong word) is 9 cells, which sort of defined voltage supply headroom for many analog chips.
jh
GarMan
Reply #5 on:
19 Dec 2006, 10:54 pm »
Hypothetically, would there be any problems if I wired two 12V car batteries as 24VCT to a battery powered Bugle? No need to change batteries for years.
hagtech
Facilitator
Reply #6 on:
19 Dec 2006, 11:27 pm »
Lots of people have done this. Only usually with a smaller SLA type.
One good thing about car batteries: if you have a solder ball short or some other assembly flaw, it's often real easy to find.
jh
Other Stuff
Hagerman Technology
hagtech
