Shanling t100 t200 tube cage removal assistance?
0 Members and 1 Guest are viewing this topic. Read 977 times.
carusoracer
« on: 19 Dec 2006, 01:36 am »
I can not get the lower tube cage ring off my Shanling T200A CDP.
Can anyone assist?
What's the trick here. I see thread in the posts but they do not turn...Trying to do some  tube swapping and the WE 396/ Raytheons are very hard to remove and are much smaller. :scratch:
nathanm
Re: Shanling t100 t200 tube cage removal assistance?
« Reply #1 on: 19 Dec 2006, 04:44 am »
I figure the lower tier must be bolted from inside.  Just take the top section off and then wiggle the tube out with your fingertips.  Try putting a rubber band around the tube to get a better grip maybe.
R_burke
« Reply #2 on: 19 Dec 2006, 03:47 pm »
I've done all of my tube swapping on my CD T-100 with just the top portion removed.
Like Nathanm suggested I just wiggle the tubes out with my fingertips, and BTW I have short fat hands and I am still able to do it this way.
