interconnect for mapletree ear+/NAD 710 and Grado SR325
0 Members and 1 Guest are viewing this topic. Read 3060 times.
canali
I'm about to receive the Ear + purist (using grado sr325 headphones)
and would really appreciate some sound advice on purchasing a good
interconnect cable compatible with this system
(The interconnect would be for hooking up the Ear+
headamp to my NAD 710 integrated amp/receiver).
Some I've done research on have been the Nordost Blue Heaven
and Harmonic Technology Precision Link.
Any useful suggestions (without breaking the bank) would be most appreciated.
Cheers
Joe
Vancouver (Olympics 2010) BC
amandarae
« Reply #1 on: 4 Jul 2003, 08:13 am »
Joe,
Please go to AudioAsylum-cables section.  Look for Bogdan Cables, there are alot of post there regarding the cables.  I have their Silver IC's ($89 per pair, 3 ft. with Eichmann bullet plugs)and compared it to a Nordost Blue Heaven (which I also have).  IMO, the Bogdans are much better than the Blue Heavens.
Also, some of the cables that really stir a lot of passion here in Audio Circle are Bolder cables and Empirical Audio (I have the Holophonics and they sound great!) cables.
I hope this helps
Sean Jones
How about this option.....
« Reply #2 on: 4 Jul 2003, 11:57 am »
Why not just build your own ? Then they are custom length, and you can save a lot of coin. I use Neutrik connectors, and get my cable from :
http://mcmnewarkcom/NewarkWebCommerce/mcm/en_US/support/search/searchResults.jsp?action=1&First=0&jsessionid=null&UNSPSC=&NPart=50-2175&MPart=&APart=&MName=&KWord=&advancedSearch.x=22&advancedSearch.y=12
canali
interconnects for grado325 and mapletree
« Reply #3 on: 4 Jul 2003, 04:38 pm »
The reason i don't build my own is that:
1-I am new to this area
2-hopelessly technically inclined, i.e., when going camping
why aren't there electrical outlets in the trees? :)  :) :)
joseph_r
« Reply #4 on: 11 Jul 2003, 10:18 pm »
I am using a similar configuration
Mad Ear+
Mad Line2
Yamaha dvd-s2300
Grado SR-325
Im using Grover Huffman Silver Interconnects for everything and
they sound amazing.  they where $60-75 for like a 0.5 meter
to find out more information goto www.stevehoffman.tv
and check out the hardware forum there should be a post
at the top about grover interconnects.
they might not look like much but they sound amazing
Joseph
