0 Members and 1 Guest are viewing this topic. Read 8174 times.
FWIW, the new Mouser catalog came in the mail this week and I see they are now carrying Wima.
I'm finding it hard to find a UK retailer with these, so I may have to order from somewhere abroad, perhaps Mouser.
I haven't checked the PCB yet to see if any other sizes can be fitted, but I'm guessing it will be more or less tailorred for those exact sizes. Hope this helps.
Hard for you???? Just imagine how hard it is for us when you don't bother to tell us WHERE you would like to source them from and you've not bothered to elucidate in your avatar.
QuoteI haven't checked the PCB yet to see if any other sizes can be fitted, but I'm guessing it will be more or less tailorred for those exact sizes. Hope this helps. Moderator's hat on You're guessing and you hope it helps????No, it doesn't. I realize that you're excited and rar'n to go, but guess based info is simply not enough, especially when a little effort on your part would eliminate those guesses. Nor is the chipmakers suggestions that you did provide necessarily close to the actual implementation of 41hz. Tripath's suggested vallues, leadspacing, etc... in their demo board doesn't necessarily jibe with 41hz's. Measure the lead spacings, read the provided schematic and/or the actual caps and tell us their actual values. This will let everyone save time and effort, and you might actually get some useful information.Hat off
Here are links to (mostly) GB based component suppliers -http://www.acoustica.org.uk/t/naim/suppliers.html
...and the MPK4 for the 7.5mm...
...it might be easier to source them from the States...
All things being equal, a higher voltage rating is preferable due to the higher effective dv/dt.
Sorry for being so harsh, I get cranky late at night when I should be sleeping.
