Firing RM 40's Straight Ahead
0 Members and 1 Guest are viewing this topic. Read 1533 times.
ka7niq
    • Roof Cleaning Tampa FL
« on: 15 Dec 2006, 06:57 am »
I almost "feel guilty", but just for kicks, I spaced my RM 40's faily wide apart in an equilateral triangle, and fired em straight into the room.
I sit in the center, and could care less about someone unfortunate to be off center.
The effect is interesting, and they seem to have a bigger sound this way, in my room.
Tuning wise, does anyone know the ramifications of running them this way
I seem to be able to reduce my midrange level to get a warmer sound, w/o hearing the upper end of the woofer.
Firing in front of me, I am unable to reduce my midrange level much below the stock setting or I can hear the woofers upper end, I think ?
Any comments ?
Anyone know when waveguide will be availiable for old spiral RM 40's ?
warnerwh
Re: Firing RM 40's Straight Ahead
« Reply #1 on: 15 Dec 2006, 07:00 am »
You can get the waveguides now. The spiral tweeters use the same one. However you probably will need a different passive crossover if your speakers are over 2.5 years old.
ka7niq
« Reply #2 on: 15 Dec 2006, 07:45 am »
Well Warner, i am having a blast with my old RM 40's.
I like em firing straight ahead, for now.
It is giving a huge sound, with incredible imaging, in my room.
My room is pretty wide, and they are minimum 4 feet from side walls.
Man, if I could get just a little more warmth ?
The sound is almost electrostatic like, maybe better, with incredible detail.
Maybe a mid woofer upgrade and crossover point  change is in order ?
warnerwh
« Reply #3 on: 15 Dec 2006, 08:37 am »
The better midwoofer is a must imo. It made a huge improvement in the upper bass lower midrange. That would add the warmth you may want. Also I use a hybrid power amp on the planar/ribbon sections. That helped significantly also. It's just a very little bit but made a significant improvement.
On cones I'm not sure I'd like a hybrid or tube amp but on these speakers with their speed it's a worthy endeavor.
ka7niq
« Reply #4 on: 15 Dec 2006, 01:48 pm »
My Moscode 600 is finished, I may hook it up ?
I  am presently using a big Adcom 585
