I've owned 2 Arcam's (Alpha and Delta series) and auditioned the CD72 and CD92. The CD72 or 92 sounded identical to me. I think they sound really smooth with detail. The sound is very clean. Nice stuff. I also like the $1,k Marantz CD player... can't remember which model. Similar qualities to the Arcam but, somehow seemed a little better.... can't remember why.... not a huge difference, though.
Then, I tried a Pioneer DVD player as a transport with a separate DAC that I won in a contest. The DAC was a Museatex which is old and not made anymore. The sound was at least as good as the Marantz or the Arcam. I would say it was as good as a Rega Planet.
I've since had the DAC modified by its creator to be signifigantly nicer, bought new interconnects, and had the Pioneer modified by Dan Wright.
I'd put my sound up against Hantra's any day.
His puny Scott Nixon DAC is no match for the modified madness I've created.
Kidding aside, The SN DAC is a different kind of sound and everyone has their preferences. If you liked the Arcam, buy it. You can always improve on its internal DAC by obtaining the outboard processor later.
However, if you're feeling a little adventurous, buy a Pioneer DV-656a and have Dan W do some mods on it... Buy a $250 DAC (like the SN), and all total you will have spent under $750 for something that will blow away most others. It's a recipe you'd have to hear to believe.
