Opinions on Polk LSI 9's or Triangle Titus?
0 Members and 1 Guest are viewing this topic. Read 1254 times.
skchow
« on: 3 Jul 2003, 05:21 am »
Going on the audio merry go around again, and looking for another set of speakers.
Looking to buy a bookshelf sized speaker for a bedroom setup and the two speakers listed above are on my short list of what to buy.  Any opinions or comparisons on the two?  Any other speakers I should be aware of also?  Budget will be maxed around 650.  Equipment will be Norh CD-1|Music Hall MMF-7 -> NAD C160 -> Le Amps.  Thanks.
Sunny.
Brad
« Reply #1 on: 3 Jul 2003, 01:49 pm »
If you're going without a sub, you might consider the next model up in the Triangle lineup, the Comete.  Should still fit in your price range and will provide better bass.
Triangles do very well with tubes.
Have you had the cap removed from your LeAmps?
skchow
« Reply #2 on: 3 Jul 2003, 02:17 pm »
yep,  the leamps' caps are removed.  Bass ain't all that important to me, worse comes to worst I'll get one of em Yamaha YST 205s for fun.
Sunny.
