0 Members and 1 Guest are viewing this topic. Read 2340 times.
Two observations:First, we would normally want any sizeable radial lead capacitors to be firmly seated on a PC card when soldering their leads. Letting them flop back and forth like the sample above will eventually cause a fatigue failure of the joint.Second, Moretite is definitely not recommended in electrical components, I understand it has an acid component that can slowly corode electrical contacts. Hot melt glue would be a better choice.Regards,Frank Van Alstine
I am not familiar with Blue-Tac? is there a manufacturer's specification sheet for it. That will normally list toxic and health issues.Frank Van Alstine
I think these PCB boards in the Mhdt Labs DAC units may be double-sided (I didn't know there was single vs double sided boards). These DACs do have components soldered to both sides, and the solder connections of top components also is visible from the bottom (like with a computer motherboard for instance). Does this mean double-sided?
