TB2+ or DB1+ as surrounds in my system
0 Members and 1 Guest are viewing this topic. Read 1293 times.
canucks0
« on: 7 Dec 2006, 11:26 pm »
Hello,
 I own some IB1's and a CB6 for my centre. I am looking for surrounds to complement. How would the TB2+'s or the DB1+'s complement. I understand that the tweeter is the only similiarity with the IB1's and the CB6. By looking at these bookshelf speakers am I straying too much from the similiarly voiced IB1's and CB6 in that they use the same mid and tweeter. I don't do multichannel music and in HT just do movies and some sports on satellite. Room is 15 X 20. Thanks. Dave
Tom Barron
Re: TB2+ or DB1+ as surrounds in my system
« Reply #1 on: 8 Dec 2006, 10:29 am »
Hi Dave,
the DB1+ and TB2+ share an important factor with the IB2 and CB6.... they have the same designer!
They are voiced using the same criteria and will be fine for use in a multi channel system.
TheTB2+ would probably be the better choice as it's more efficient, has a higher handling capacity than the DB1+ and should be more able to keep pace with your IB1 and CB6.
Regards
Tom Barron @ PMC
