PS voltage
0 Members and 1 Guest are viewing this topic. Read 1793 times.
studley
PS voltage
« on: 6 Dec 2006, 12:24 pm »
Wayne
when I eventually find one to buy, I am going to have you do a full mod on an SB2.  Initially i can't stretch to the ultimate PS and will be using a modestly priced linear supply as a short term measure.  Can you therefore tell whether your modded SB2s require the same voltage as normal (5vdc I believe) and the same polarity ?
Could you also confirm for me what the polarity is?
Ian
Wayne1
Re: PS voltage
« Reply #1 on: 6 Dec 2006, 03:59 pm »
All the Squeeze Boxes require 5 volts DC.
A 2.5 mm DC connector is used to plug into the SB.
1.5 amps is the minimum current that a supply should be able to produce.
The DC connector is center pin positive.
The ELPAC WM-075-1950-D5 from Digi-Key is $40.00 and works very well for a cased wall wart.
Mods to the ELPAC do improve the sound.
studley
Re: PS voltage
« Reply #2 on: 6 Dec 2006, 04:05 pm »
Thanks Wayne
rajacat
  • Washington State
Re: PS voltage
« Reply #3 on: 6 Dec 2006, 04:45 pm »
The Power-one Power Supply works well too. I have one that Wayne modded and it sounds good to me.
Raja
richidoo
Re: PS voltage
« Reply #4 on: 7 Dec 2006, 11:05 pm »
The Power-one Power Supply works well too. I have one that Wayne modded and it sounds good to me. Raja
I second that on the Power-One. Even stock, it sounds awesome on SB3 and ripple spec is 50x better than the elpac.
Rich
JEaton
Re: PS voltage
« Reply #5 on: 8 Dec 2006, 12:09 am »
What's the model number of the Power One supply?
