0 Members and 1 Guest are viewing this topic. Read 10316 times.
Harry Ferdinand Olson (1957) ?/Erling
John,That's still a circular baffle.....just bent back. Frequencies of appropriate wavelengths won't even recognize it's "stepped." Have you performed any measurements at all or is this strictly a subjective assessment? I think you're still going to see a strong peak at a frequency where the front/back distance is a multiple of the wavelength.Cheers,Davey.
What about putting the driver in the middle of a donut?I like this idea.
Over the frequency range were the front and rear radiation are symmetric the edge diffraction from the front and cancels and what you are left with is the summed front and delayed rear response.
(JPK) ... There at then 4 components which sum form the on axis response. 1) the direct response from the front source. 2) the delayed direct response form the rear source, 3) the diffraction of the front direct source from the baffle edge, and 4) the diffraction of the rear direct sound from the baffle edge. ... Now consider 3 and 4. For a hypothetically infinitely thin baffle, 3 and 4 will be identical in amplitude but 180 degrees out of phase because they both represent the diffraction of the same signal (symmetric front and rear responses) and are both delayed by the propagation time to the baffle edge. Thus they cancel at the baffle edge and do not contribute to the on axis response.
