0 Members and 1 Guest are viewing this topic. Read 4286 times.
Some ramblings about adding an active crossover to my system.Back in 2002 I read all of Rod Elliott's articles on actively bi-amping ... My current speakers (Meadowlark Blue Heron 2) have a readily accessible XO so that part was not a problem. Re-reading all of Rod's articles he suggests cross over points of about 300Hz and 3600Hz as this is the most critical range for intelligibility. This is a pretty wide range for a midrange driver to cover as it needs to play well for an octave below and above the crossover frequencies. Since the BH2's are first order speakers they need to use high quality drivers to work well and looking up the specs for the midrange (ScanSpeak 12M/4631) showed an Fs of 75Hz and is -3dB at about 175Hz, so the low end appeared like it would be usable. The existing mid to high XO was at 4K, close enough to 3k6 to not worry about it. I set the low to mid crossover to 275Hz using Linkwitz-Riley 4th order slopes. I left the internal passive mid/high network in place including the baffle step compensation. I had high hopes for the sound and thus far the results have exceeded my expectations. Bass is amazingly tight since the amp is directly coupled to the drivers and doesn't have a large inductor in series to cause problems.Granted this is not a trivial exercise and is certainly not for everyone, it has turned out great and was well worth the time and effort. mike
With all due respect to Dan's amp, try some tubes on top and see what you hear. aa Also, UcD or ICE amps are great with woofers.
1. I also read all of Rod's articles and in fact use his crossover PCBs. Yes, he says the theoretical "best crossover points" are 300Hz & 3600Hz but in the real world you have to stick with what your drivers are capable of ... my IIIa crossovers for instance are 300Hz and 2600Hz (because my mid-range driver won't go up that high!).
2. First up, I built Rod's 24dB L-R XOs in a 3-way format. But then I built a second pair using the stock Maggie IIIa slopes (18dB bass LP/12dB mid HP & 12dB mid LP/12dB ribbon HP) ... and these sound much better.I suggest it's possible your Meadowlark BH-2s would sound "even better Smile)" if you changed the bass/mid crossover slopes to 6dB (some Marchand models let you do this and Rod's XO PCB certainly does) AND stuck to the stock XO frequency.
3. Whatever sonic benefit you can hear with an active bass/mid XO, you will get more of with an active mid/tweeter XO ... so why not go 3-way active!!?? Smile) If you do this, you would have to leave in place the passive baffle-step compensation ... plus, I suggest, any driver impedance compensation components (IMO, they are not part of the XO network!).
Did you find any changes in room /loudspeaker issues? Or in your initial findings did you find that with a partial active crossover the room loudspeaker issues were increased or decreased. Did the typical room gain that many speakers have in the bass either, lessen, increase or no change at all?
If you've got the equipment or can get your hands on the equipment try pink noise with a real time analyzer and compare room gain at low frequencies with and without the active crossover. My bet is that there is a difference, and the room gain is lower. d.b.
Thanks for sharing. But might I suggest that in effect you've only created a passive 2-way with powered subwoofers. You're still only half way home to enjoying the full benefits of going fully active.
Mike,Thanks for sharing. But might I suggest that in effect you've only created a passive 2-way with powered subwoofers. You're still only half way home to enjoying the full benefits of going fully active.Years ago I had the chance to compare $800/pair Paradigm Studio 20s (typical 2-way standmounts) against $1600/pair Paradigm Active 20s (pretty much a straight passive to active conversion of the same design). The Actives blew the Studios away, not even close. Much more dynamic, ruler flat response, and incredible bass output. They both had the same Paradigm family sound, but a fairer comparison would have been against the Studio 100s ($2000 full sized floorstanders). Other customers gawked in disbelief at the bass and dynamics coming from standmounts. Their performance was amazing, the 2nd and last audio epiphany I've had.From that day I was convinced that active is the only way to go for any serious speakers or audio system. I might conscend to a two-way using a super tweeter with protective cap (like the DeCapo 3A). Too bad that most audiophiles haven't heard actives or accept accounts like these. And unfortunately most active speakers are designed for highly analytical or high output professional use. IMO the money spent on expensive passive speakers is mostly wasted. BTW the active advantages also explains why us owners of single driver speakers aren't completely out in left field.
Over the holiday I had a chance to make an in room measurement. While not flat it's not too bad for a system that's not using any type of EQ such as a TacT. Since the XM44 is on loan I'm thinking of going with a DCX2496 so that I can apply some (light) EQ to smooth out the bass a bit. My hacked RS SPL meter I used for measuring is supposed to be pretty flat to about 10Hz but the HF response is almost non existent, so the drop above 8K is from the mic, not the room.
I also think that going completely active is the way to go. ... have to consider the cost of ... something to equalize the sensitivities of the amps.
