TX102 Remote Kit question
0 Members and 1 Guest are viewing this topic. Read 2801 times.
Allen
« on: 1 Jul 2003, 09:19 pm »
Just to avoid any nasty surprises, is it possible to get the stepper motor to run in the opposite direction?
The only way I can fit the motor into my pre is to have the motor facing the 24 pos switch rather than alongside it.
This means that when pressing 'up' on the remote the volume will decrease and vice versa, can I rewire so that it runs the opposite way?
I've already tried inverting the red and blck wires with no joy.
Thanks in advance
John Chapman
    • http://www.bentaudio.com
« Reply #1 on: 4 Jul 2003, 05:11 pm »
Hello!
Sorry for the late reply! I usually keep on top of the board here but was away for a bit. Back at it now....
I can picture what you are doing with the motor mounting. Because it is a stepper motor reversing the leads does not change directions like it would with a DC motor.  It is run from step to step by the microcontroller board and to change direction the steps must have their order reversed. It's easy to flip in software and I can send you over a new controller chip - just shoot an e-mail through to [email protected] and we'll get the new chip made and on it's way.
Many Thansk!
John Chapman
www.bentaudio.com
Allen
« Reply #2 on: 5 Jul 2003, 03:59 pm »
Thanks a lot John, mid boggling service as usual :o
I'll e-mail
Allen
Allen
« Reply #3 on: 16 Jul 2003, 10:59 pm »
Thanks again John,
Works a treat!
John Chapman
« Reply #4 on: 16 Jul 2003, 11:10 pm »
Hello!
Glad it arrived in good time.  Also glad it worked out!
John
