Piano MLS
0 Members and 1 Guest are viewing this topic. Read 1693 times.
tbrooke
Piano MLS
« on: 30 Nov 2006, 04:54 pm »
I was just reading about he Piano MLS finish and I was wondering if I can do this myself. I have the African Ebony MLS 626R. I'm not sure I would actually do it but the pictures look pretty impressive - I'm happy with the satin finish but the glossy looks good in the picture and I may give it a try if it is doable. A couple of hours of rubbing wouldn't hurt me.
Tom
Brian Cheney
    • http://www.vmpsaudio.com
Re: Piano MLS
« Reply #1 on: 30 Nov 2006, 04:57 pm »
The glaze is 3M 05996, available at Carquest, Napa and other auto parts outlets.  You'll need a good electric buffer with a cotton pad.
Brad
Re: Piano MLS
« Reply #2 on: 30 Nov 2006, 05:38 pm »
A couple of hours of rubbing would be good for MOST of us  :lol:
Haha - Sounds like you can take your speakers to the next cosmetic level with a little effort.
Let us know how it works out.
warnerwh
Re: Piano MLS
« Reply #3 on: 30 Nov 2006, 10:40 pm »
Thanks for the info Brian. I thought about using a car glaze but didn't know if it would harm the finish. Being as I have a bottle of Meguir's car glaze I guess I'm forced to do it.
