Torus for 4Bsst
0 Members and 1 Guest are viewing this topic. Read 1608 times.
rabpaul
Torus for 4Bsst
« on: 30 Nov 2006, 07:16 am »
James,
My Bryston Dealer has recommended the International 4A Model - A010-BCA-B1AH
Would this be adequate?
Rgds
Rabin
  • The Demo is Everything!
    • http://www.bryston.com
Re: Torus for 4Bsst
« Reply #1 on: 30 Nov 2006, 01:04 pm »
HI Rabin,
Sorry what is the gear you are hooking up again?
If it is a single 4B SST then maximum current draw at 240 volts at 4 Ohms is 8 amps.
At 8 ohms it is 4 amps
So you would need the International 8 Amp unit or 4 Amp unit depending on your speaker load..
james
« Last Edit: 30 Nov 2006, 04:03 pm by James Tanner »
rabpaul
Re: Torus for 4Bsst
« Reply #2 on: 1 Dec 2006, 03:41 am »
Hi James,
The 4Bsst will drive a Thiel 2.4
So you recommend an 8A model rather than a 4A model?
Rgds
Rabin
Re: Torus for 4Bsst
« Reply #3 on: 1 Dec 2006, 12:37 pm »
Hi James,
Rgds
Rabin
Hi Rabin,
Yes I would say go with the 8 amp. In the long run it will be a better choice. Also you could plug in all your other gear as well.
james
