How do you update software on SP1.7
0 Members and 1 Guest are viewing this topic. Read 1886 times.
Tony1
« on: 29 Nov 2006, 01:10 am »
I've read posts here where updates are sent or posted on the Bryston website.  How are they updated to the unit?
  • The Demo is Everything!
    • http://www.bryston.com
Re: How do you update software on SP1.7
« Reply #1 on: 29 Nov 2006, 01:12 am »
HI Tony,
The updates ae only available for the SP2.
james
Tony1
« Reply #2 on: 29 Nov 2006, 04:07 pm »
How is the software updated on the SP2?
« Reply #3 on: 29 Nov 2006, 04:20 pm »
Through a file you load through the RS-232 port on the back of the SP2.
james
alpsy
« Reply #4 on: 30 Nov 2006, 12:42 pm »
james
is it an easy process james are are the updates available for download on your website?
cheers,
julie
« Reply #5 on: 30 Nov 2006, 12:57 pm »
james
cheers,
julie
Yes it is very straight forward.
They are on the website or if you email me I can email you the instructions and the update file.
james
