Best Practice for Clari-T Discharge, Recharge Cycling?
0 Members and 1 Guest are viewing this topic. Read 1671 times.
DRCope
  • Wand 14-4 ‘table, wand arm, Dynavector, Pure Audio
    • Old Forge Audio
Well, I did a search, and while I suspect it's in here somewhere I can't find it, so here goes:
What is the recommended discharge/recharge behavior to max the life on a Clari-T?
Only recharge when deeply discharged?
Recharge after any period of use, no matter how short?
Is it important/critical to let it come back up to 'green' before switching back and listening again?
I'm using the amp (more than) enough to be concerned about doing it right . . .  :thumb:
Vinnie R.
    • http://www.vinnierossi.com
Re: Best Practice for Clari-T Discharge, Recharge Cycling?
« Reply #1 on: 27 Nov 2006, 01:26 pm »
Hi DRCope,
Here is a link that should be useful (scroll down):
http://www.redwineaudio.com/SLA.html
Did you receive a Clari-T User's Guide when you purchased it used?  If not, please email me and I'll email you back with one.  It explains everything in detail.
NEVER deeply discharge!
Correct!  :thumb:  And you can leave the charger always connected to the Clari-T (as long as the charger is connected to a live AC outlet), so the operation is really a matter of switch UP = ON, and switch DOWN = OFF/CHARGE.  That is all there is to it  :wink:
Well, if you have the small Clari-T with the 1.3Ah battery that is rated for a max play time of 6 hours, and you only charge for 2 hours, DO NOT play for another 6 hours if you didn't fully charge.
Hope this helps,
Vinnie
DRCope
    • Old Forge Audio
« Reply #2 on: 27 Nov 2006, 10:29 pm »
Thanks Vinnie!
Nope, I didn't get a manual with my Clari-T. It would be great if you could email me a copy.
For that matter, I'd be happy to buy a badge for it. Currently it's anonymous and quite stoical looking in all black.
Yep, the charger stays plugged in and connected full time, with appropriate upping and downing.
