Hi Larry.
>>This seems contradictory to the general consensus of CAT5 and cross-connected coax at large
Ahh, but the "consensus people" are comparing CAT 5 using the UBYTE design, not loosely braided, using 8 individual strands.
The rest of your post then seems to deal with comparing "NOT" teflon coated CAT 5 cables against "NOT" 89259 cables and making a judgement that 89259 cables are better than CAT 5. Surely this is not a valid judgement.
A couple of years ago, Vic made up some cross coupled cables using air cored satellite cable (not 89259). They were good.
I made up some CAT5 cables using the U-Byte recipe (not using teflon coated). They were pretty good, not as good as the cross coupled cables.
We both replaced our cables (mine were old Audioquest, Vic's were Monster Cables). I was chuffed that I had made DIY cables. At that point, we agreed that any old cross coupled was better than any old CAT 5.
But the problem was that we both were not using the "correct" cable to begin with.
I then read about the Chimera cable. Very interesting reading. I took on board the methods of using it (loosely braiding a few individual wires).
I purchased some teflon coated solid core CAT 5 from Rat Shack, when I was on holiday in USA.
I then made up 16 strands of teflon coated solid core CAT 5 (unwinding all of the pairs, braiding 4 strands together (4 times) then braiding the 4 braids together. It was a lot better than the cross coupled cable and the PVC coated CAT 5.
Three of us then went thirds in a 1000 foot roll from USA. We were very happy with the results.
I then went fom 16 strands down to 8. It was even better (removed some grain), but this is probably an AKSA (capacitance) thing. If 16 is good and 8 is better, then let's try 4. 4 sounded weaker. It appears that 8 strands is optimal (no, I haven't tried 12 or 14).
I had the opportunity to audition the "real" 89259 cross couple cables of John R. The consensus is that the 8 strand solid core, teflon coated CAT 5 is better than the "real" 89259.
Turning to amp/speaker combinations, Vic and I both have Nirvana AKSA 55 power amps. My speakers are Diatone full range with an active sub woofer, Vic has Ambience ribbon hybrids. Ambience speakers have an impedance of 6 ohm and are about 86 db efficient. They go very high, they go very low. They are very nice.
The Diatones are paper coned 6 inch speakers, impedance of 16 ohm, about 92 db efficient. They go highish (probably better than my 57 year old ears), they do not go low (down to about 70 hz). They also sound very nice.
Whatever experiments we have done, we always seem to agree. We both prefer 8 strands to 16 in both systems, we both prefer any old cross coupled speaker leads to any old CAT 5, we both prefer 8 strands of teflon coated CAT 5 to anything else that we have tried etc. The bass is very good using 8 strand (listening to the Ambience). I can't comment on the Diatones (they have no real bass).
For the Chimera stuff, have a look at
http://home.att.net/~chimeraone/audiocable.html
