james, I have sent you pm
0 Members and 1 Guest are viewing this topic. Read 3020 times.
bgewaudio
« on: 24 Nov 2006, 05:37 pm »
james,
I have sent you a pm regarding my problem with my BP26DA.
  • The Demo is Everything!
    • http://www.bryston.com
Re: james, I have sent you pm
« Reply #1 on: 24 Nov 2006, 06:22 pm »
Ok - regarding the remote?
james
bgewaudio
« Reply #2 on: 24 Nov 2006, 07:31 pm »
No, sorry, guess I should have been more specific.
I had told you awhile back that I was experiencing some issues with regards to a defective receiver chip.
The unit was sent out Monday, so it's probably at your facility as we speak.
just wanted to see if you had received it yet?
bgewaudio
« Reply #3 on: 24 Nov 2006, 07:32 pm »
Also did you happen to get any T-shirts in yet?
« Reply #4 on: 24 Nov 2006, 07:34 pm »
Hi,
Does not appear to be here yet - will check Monday.
james
« Reply #5 on: 24 Nov 2006, 07:40 pm »
Sorry - no T-Shirts yet.
james
bgewaudio
« Reply #6 on: 24 Nov 2006, 07:43 pm »
Thanks James!
bgewaudio
« Reply #7 on: 28 Nov 2006, 04:51 pm »
James,
Just wondering if you've received my BP26DA for repair yet?
Barry
« Reply #8 on: 28 Nov 2006, 05:43 pm »
Hi Barry,
Yes we have the BP26 and we are checking it out at this moment.
james
bgewaudio
« Reply #9 on: 28 Nov 2006, 06:05 pm »
Excellent,
I should also metion another symptom to maybe help in finding the problem, is I've also notice the sound sometimes to be tiny, like there is a fuzzy bell ringing in the background.
You may have to open the CD drawer to establish the signal over and over again before you will actually hear the sonic discrepancy.
Hope this helps
Barry
bgewaudio
« Reply #10 on: 11 Dec 2006, 12:12 pm »
James,
Did you happen to notice the problem with the BP26 I was talking about while you had it home for those couple of days?
« Reply #11 on: 11 Dec 2006, 01:13 pm »
Yes I did - it sounded like it lacked dynamic contrasts and was rolled off.
We have installed a new DAC for you and the preamp is on the way back.
james
bgewaudio
« Reply #12 on: 11 Dec 2006, 02:40 pm »
Thanks so much
your quality control and customer service has been outstanding in this matter.
So yourself and the engineering dept was in agreement that the DAC was the main cause of the problem?
Did AC power descrepancies have anything to do with the demise of the DAC, or was it just defective?
When was it shipped out by the way?..... Kind of anxious.  aa
« Reply #13 on: 11 Dec 2006, 04:18 pm »
Thanks so much
Hi,
CS8421 DAC was defective. I believe it went out Friday.
james
bgewaudio
« Reply #14 on: 11 Dec 2006, 04:21 pm »
Thanks again James for your prompt responses.
you guys are great!
bgewaudio
« Reply #15 on: 13 Dec 2006, 05:34 pm »
Hi James,
Just wanted to inform you that I've received by BP26DA yesterday and it sounds wonderful, no more HF rolloff.
Thanks again
« Reply #16 on: 13 Dec 2006, 05:42 pm »
Hi James,
Thanks again
You are very welcome sir - enjoy.
james
