0 Members and 1 Guest are viewing this topic. Read 3134 times.
What I can´t estimate is the psychoacoustic influence of a sound source hung that high. You might ask hurdygurdyman, under which conditions his IB woofer in the attic is really vanishing.www.dipolplus.de
I can't play the sub by itsef, so can't listen to it or measure it without the main speakers playing. I'm driving the sub amp/XO from the output of the mains tube amp and need to keep a load on the tubes. Someday I'll get some load resistors and play the sub alone to see just how easy it is to locate it by ear.
Quote from: hurdy_gurdyman on 24 Nov 2006, 02:24 pmI can't play the sub by itsef, so can't listen to it or measure it without the main speakers playing. I'm driving the sub amp/XO from the output of the mains tube amp and need to keep a load on the tubes. Someday I'll get some load resistors and play the sub alone to see just how easy it is to locate it by ear. Dave, can you get a roll of cheap 'zipcord' and set your mains in another room (or further depending on lenth of wire) with the door closed?It'd be cheaper and easier than making a false load, wouldn't it?.Then you could hear just the sub.Bob
