Fuses
0 Members and 1 Guest are viewing this topic. Read 1427 times.
mark funk
Fuses
« on: 22 Nov 2006, 11:58 am »
Frank, Martyo is letting my use his Carver Platinum speakers. He is using a Carver TFM 75 amp rated at 750 watts a side in his set (I hope he does not blow up my Dhalquist with all those watts). I have had a little trouble with popping the 5 amp fuses in my 550EXR6. I was wondering if I could use a 6 amp fuse, would this hurt the amp or the speakers? The Platinum's are fused with 4 amp fuses. Thanks  :smoke:
martyo
Re: Fuses
« Reply #1 on: 22 Nov 2006, 02:14 pm »
Frank, thats 2 4 amp fuses per side, 1 each for the ribbon and woofers. Okay mark funk, I'm not going to blow up the DQ10's.
avahifi
    • http://www.avahifi.com
Re: Fuses
« Reply #2 on: 22 Nov 2006, 07:54 pm »
No problem using six amp quick blow speaker fuses with the Ultra 550 amplifier.  Although if you are blowing 5 amp fuses, you are putting over 200 watts into the speakers, and thinking about how much heat two 100 watt light bulbs generate, and putting that much heat into a voice coil, I would suggest that overdoing it could melt the voice coil wires.  Caution!
Frank Van Alstine
