0 Members and 1 Guest are viewing this topic. Read 6029 times.
It's not comprehensive in that it doesn't take into account every last nuance of your listening environment
but it's the best out there and does a fine job to boot. I highly recommend it.
As for what is discussed on forums, I don't believe any of it.
I had not seen that analysis before. I did a quick read and can offer the following off the cuff comments.
1. His monopole souce has to be a sealed enclosure, a TL or BR is a dipole souce at low frequencies below the cut-off. So in some ways I think he is talking apples and oranges. My Alpha 15A drivers have a fs of about 40 Hz, so for an equal comparison a sealed system would need to be used that is tuned to the same 40 Hz. For many of the small two way sealed systems most DIYers build I don't think they get to 40 Hz. For a sealed sub that goes down to or below 40 Hz I think that the major reinforcement is due to floor or corner loading.
2. His assumption is that the room is tightly sealed so that it can be pressurized.
3. I believe that my OB system easily reaches down to 40 Hz, it is a big baffle.
4. As for what is discussed on forums, I don't believe any of it.
... While the front wave and it's reflections reinforce and buildwhere the on axis room dimension = 1/2 wavelength, the rear wave should act inthe same manner, at the same frequency, along the same axis, to create a null,not a peak. Am I missing something in my simplistic visualization? ...
