Omega Sig 30 - You'll Enjoy This From a Knucklehead
0 Members and 1 Guest are viewing this topic. Read 1853 times.
spostva
  • The Music Never Stopped
« on: 21 Nov 2006, 09:08 pm »
:slap:
I received my amp a couple of weeks back. I was a little curious why it seemed not to have much kick.  It's hooked up to a pair of Omega XRS's and an un-moded SB3 playing FLAC encoded tunes.  As a sanity check, I hooked up a CD player and was amazed at the power!  After some head scratching, I re-attached the SB3 and...TURNED THE PLAYER VOLUME UP TO 100% (from 50%).
What a jackass!  I can say [now] the clarity, quality, power, etc. are all more than I expected.
Kudos to Vinnie and Louis for the outstanding quality and craftsmanship in their products.
I'll try to get pic's posted this weekend.
Happy Turkey Day to All,
Mike
:banghead:
robert1325
Re: Omega Sig 30 - You'll Enjoy This From a Knucklehead
« Reply #1 on: 21 Nov 2006, 09:46 pm »
That was a bit  :duh:   ,    you should get your SB3 modded,   you''ll be amazed!
Loftprojection
« Reply #2 on: 21 Nov 2006, 11:51 pm »
Yes get your sb3 modded, my RWA SB2 is incredible.  Also, why don't you configure the volume out to fixed in your slim server settings, I guess you have a remote on your sig30, in theory you will get a bit better sq and you will never have to worry about not getting full volume...
Vinnie R.
    • http://www.vinnierossi.com
« Reply #3 on: 22 Nov 2006, 02:01 am »
Thanks, Mike!
That is a gorgeous amp and Louis will be adding new pics to his site soon.
No worries about being a knucklehead  :duh:   :wink:
