Bending up bigger caps
0 Members and 1 Guest are viewing this topic. Read 1515 times.
aurelius
« on: 21 Nov 2006, 02:21 am »
Hi Jim,
Almost finished building my Chime... looking forward to getting it up and running over the next couple of weeks.
In the process of ordering parts, I decided to upgrade all 1uF, 600V film caps (4 x B+ bypass, 2 x signal caps) to VH Audio OIMP caps.  (I have been curious about these for a while and decided to kill two birds with one stone).
Problem is, they're a tad bigger than the lead spacing on the board.  To install them, I put heat shrink around the leads and then bent the leads back under the capacitor body, then at right-angles to meet the hole spacing requirements.  Each capacitor is sitting maybe 1/4" above the board.
Is there a better way to do this?
Mark C.
hagtech
Re: Bending up bigger caps
« Reply #1 on: 21 Nov 2006, 02:44 am »
Not really.  Sometimes I glue them down with silicone to reduce vibrations.  Long leads act like guitar strings.
jh
PatOMalley
  • This text is personal
    • http://home.comcast.net/~omaille/audio/home.html
« Reply #2 on: 21 Nov 2006, 05:27 pm »
I have seen installation where the cap is on end so that one lead is very short and the other lead is longer coming down as shown below:
JH, Is there anything wrong with doing it this way?
aurelius
« Reply #3 on: 24 Nov 2006, 09:49 am »
Thanks Jim & Pat.
