Slim Devices Transporter High Performance Mods/Rebuilds for all budgets!
0 Members and 1 Guest are viewing this topic. Read 1807 times.
Reference Audio Mods
    • http://www.referenceaudiomods.com
Slim Devices Transporter High Performance Modifications/Rebuilds
Inquiries:
WorldWide Service:
Doug Jesse RAM East (Warren, Michigan)
[email protected]
phone (586)944-5611
Kyle Takenaga RAM West (Riverside, California)
[email protected]
phone (951)780-2869
The Transporter has worldwide voltage capabalities and we can work on
transporters that can be dropped shipped in for mods, or you can send us your
transporter from anywhere
in the world. We will adjust and add the extra international shipping fees
into the price, please email for quote.
Introduction :
Slim Devices has come out with their best product yet, the Transporter. This
is the highest end music streamer they offer and it uses very good electronic
topologies in comparsion to their competitors products.This is a great
platform to modify from and be able to produce world class sound from your
music file collection. Reference Audio Mods has now stepped up to the plate
to bring the industrys first available high performance modifications
and rebuilds to this great product. If you are listening to a stock
transporter, you are missing so much! We have developed 3 different
mod/rebuild packages to suit all budgets.  Extract the most sound from your
transporter!
Modification Packages and Descriptions:
"Budget Modification Package ($595 Installed/Shipped)
Designed for audiophiles on a budget who want better performance than the
stock unit. This is basically a "parts swap" upgrade and well worth it.
Eliminates the glare and grain and improves soundstaging, resolution/dynamics
and clarity. Only recommended if the $995 or $1395 is out of your budget (we
can upgrade you to those mods if you decide to get this mod package for the
price difference between the packages).
Power Supply mods-
Add Furutech IEC Connector, Replace stock noisy diodes with RAM Ultra Low
Impedance Handmade Diode Bridge, Replace an abundance Voltage rail capacitors
with Ultra Low Impedance Rubycon ZA/ZL caps in power supply and for analog
decoupling.
Analog Output mods-
Replace ALL Analog output stage opamps from the gritty sounding 5532's to the
Analog Devices AD825 opamps for a drastic change in performance. Replace
coupling and voltage rail caps with Ultra Low Impedance Rubycon ZA caps,
Replace stock RCA's w/WBT Copper NextGen and wire into circuit with Audio
Consulting Silver Wire/Cotton tubing.
"Advanced Modification/Rebuild Package ($995
Installed/Shipped)
Designed for audiophiles who are serious and have the budget to really excel
the transporter to a much further level thats beyond their expectations. This
level mods removes the entire Analog output stage and adds the Audio
Consulting Copper wire signal coupling transformer stage. This eliminates ALL
resistors, capacitors, opamps, transistors, etc.. Pure as possible! No signal
deteriotating parts! Absolute huge step forward. Eliminates the glare and
grain and drastically improves soundstaging, resolution/dynamics and
clarity.
Power Supply mods-
decoupling.
Analog Output mods/rebuilds-
Completely remove the entire Slim devices analog output stage, Add Audio
Consulting Copper Wired Signal Coupling Transformers. Wired to both XLR and
upgraded WBT Nextgen RCA connectors.
True Balanced Output now!
Eliminates ALL opamps, ALL resistors, ALL signal capacitors, All transistors,
etc. for the Purist Sonic pathway! No Mains distortions or thermal distortion issues!
A complete and drastic step forward. Soundstage widens/deepens
significantly. Inner resolution and fine details are evident like never heard
before. This will be a rediscovery to your music collection. All voltage rail
caps for the AKM DAC Chip are replaced with Ultra Low Impedance Rubycon ZA
caps. Replace stock RCA's w/WBT Silver NextGen and wire into
circuit with Audio Consulting Silver Wire/Cotton tubing.
"Premium Modification/Rebuild Package ($1395
Installed/Shipped)
Designed for audiophiles who are ultra serious and have the budget to bring
the transporter to levels thats beyond their expectations. This level mods
removes the entire Analog output stage and adds the Audio Consulting Silver
wire signal coupling transformer stage and removes the stock super regulator
circuit and replaces it will the Audiocom PPR2 Ultra High performance
discrete voltage regulation circuit. Absolute huge step forward. Eliminates
the glare and grain and drastically improves soundstaging,
resolution/dynamics and clarity.
Power Supply mods-
Impedance Handmade Diode Bridge, Replace an abundance Voltage rail capacitors with Ultra Low Impedance Rubycon
ZA/ZL caps in power supply and for analog decoupling. Replace the stock Super Regulator circuit with the Audiocom PPR2
Ultra High performance discrete voltage regulation circuit for even far less
noise and tigher voltage regulation to improve the music.
Consulting Silver Wired Signal Coupling Transformers. Wired to both XLR and
Click below for more info and Ordering:
http://www.referenceaudiomods.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=SDTransporter&Category_Code=MODS&Product_Count=44
We accept ALL forms of payment. You can also have new units drop shipped in.
We will work on any unit in the world and will add the international shipping
on the cost of the mods.
(Update: Oct. 2nd, 2007...added pic to show mods )
« Last Edit: 3 Oct 2007, 03:40 am by Reference Audio Mods »
We have successfully modified over a dozen of these now since Nov. 2006 for people all over the world and they are blown away using this great modified product with their streaming lossless audio from their computer or use with a modified CD transport or such.
