revel b12 in a 2 channel system or just a sub
0 Members and 1 Guest are viewing this topic. Read 1472 times.
norman
« on: 18 Nov 2006, 03:34 pm »
please comment on the b12
thanks    norman
Carlman
Re: revel b12 in a 2 channel system or just a sub
« Reply #1 on: 18 Nov 2006, 11:18 pm »
Congrats and welcome to AC.  The b12 is certainly a big sub.  It is well suited for 2 channel and HT applications.  I decided I did not need it with my F30's, though.  Plenty o' bass.
FYI, there's no need to post into 2 areas of the forum for general comments.  Whichever post gets legs will remain active.  Good luck.
-Carl
norman
« Reply #2 on: 26 Nov 2006, 11:56 am »
thanks    carl
the bass becomes a bit thicker
thicker bass // warmer bass:    is that better than leaner bass
what is fat as compared to warmy??
thanks a lot     norman
bpape
    • Sensible Sound Solutions
« Reply #3 on: 26 Nov 2006, 12:09 pm »
If it's purely for a 2 channel music system, I'd take a listen to the ACI subs.  IMO they're much more musical and easier to integrate.
Bryan
norman
« Reply #4 on: 26 Nov 2006, 02:45 pm »
bryan      thanks   but i bought the b12 already
i will consider aci       in the future
norman
Carlman
« Reply #5 on: 26 Nov 2006, 03:20 pm »
Norman,
Sorry but I can't interpret your questions.  You have a nice sub and you'll need to tune it to your room.  There is a lot of information on the web that can provide instructions to blend a sub with speakers.  Best of luck.
-Carl
norman
« Reply #6 on: 26 Nov 2006, 06:06 pm »
carl
the b12 is custom installed by my dealer
i feel the bass of the bass music becomes a bit warmer   not as
detail    the attack and decay is not that well defined when i turn on the sub
thanks     norman
my main speaker is the jmlab electra 926
