Bugle and Passive Pre?
0 Members and 1 Guest are viewing this topic. Read 1525 times.
pjanda1
« on: 18 Nov 2006, 06:08 am »
Will a Bugle work decently with my 25K 'passive preamp'?  Sorry if this was answered somewhere and I missed it.  I understand it may not be a perfect match, but I doubt anything else inexpensive will be.
thanks,
Paul
hagtech
Re: Bugle and Passive Pre?
« Reply #1 on: 18 Nov 2006, 06:56 am »
Should be no problem at all.  With the opamp buffers, a BUGLE could drive a 5k volume pot without breaking a sweat.
jh
pjanda1
« Reply #2 on: 18 Nov 2006, 02:51 pm »
Fantastic.  What's your take on SLA's v. 9V's?  Will the SLA's yield a big improvement?  I have a charger for 9V NiMH's, so that is the easiest solution for me.  I'm thinking about a chassis.
Also, it sounds like these may have a little DC offset.  My chip amp isn't set up to handle any.  Is there an easy way to add coupling caps?
Paul
hagtech
« Reply #3 on: 20 Nov 2006, 07:40 pm »
You might get about 10mV dc offset.  Depends on the opamp.  This should not be a problem for most amplifiers.  Adding the coupling caps can color the sound, but if necessary, just put them inline with the interconnects.
I haven't tried them, but people report here that the SLAs work great.
jh
pjanda1
« Reply #4 on: 24 Nov 2006, 03:40 pm »
Thanks!  I'll order one soon.
Paul
