center speaker mount for PMC TB2C
0 Members and 1 Guest are viewing this topic. Read 1461 times.
kas
« on: 18 Nov 2006, 04:25 am »
Hi all,
I am looking for a wall mount for my PMC TB2C center channel. It's a shame that they don't have screws on the back like the DB1s. Any ideas will be greatly appreciated.
kas
ec
Re: center speaker mount for PMC TB2C
« Reply #1 on: 19 Nov 2006, 11:34 pm »
I use a Target speaker wall mount kit.  It is an L arm with a tilt swivel.  The base the speaker sits on can be expanded but by default it is not deep enough for the TB2.  So I modified this by drilling out the base a little bit.  Works like a champ.  I may even have the extra wall mount since they come in pairs.  If you live in Toronto, let me know.
kas
« Reply #2 on: 20 Nov 2006, 09:01 pm »
Thanks ec for your response. I will check it out and let you know, and yes I live in Toronto (Bayview and Sheppard area).
kas
