0 Members and 1 Guest are viewing this topic. Read 2913 times.
What most audiophiles don't realize is that bad grounding is the cause of most of the anomalies that you have already described:"now that i've thought about my orig post, the statement that its like turning Dolby NR on and off is accurate. there is a small amount of hash & hshhhhhhhhhh & brightness that disappears completely when the racks are grounded."Think about the ramifications of what you have just said and observed in your system. Once you have absorbed that, then try the experients of going back to stock cables and observe what happens. d.b.
Back to stock cables? Isn't that a rather broad statement given you don't know what kind or how his stock cables are made? I noticed that you sell cables on your website. What happens when these cables are substituted for stock cables in a system?
Quote from: rajacat on 17 Nov 2006, 05:59 pmBack to stock cables? Isn't that a rather broad statement given you don't know what kind or how his stock cables are made? I noticed that you sell cables on your website. What happens when these cables are substituted for stock cables in a system?Dan has allways tended to broad (and oftimes accurate) statements.Dan's cables would probably drop the noisefloor further, 'specially iff'n the ground leg of your cables are some panty ass guage.....I guess you didn't do that search that Dan suggested?
"last, since what i'm putting into the ground is EMI/RFI garbage, should i try and plug all the wires onto a difft circuit? All this would change is the longest run of my rack's ground wire from 12" to about 7'."I really wouldn't worry about this. I guess it's a young guy thing to worry about the difference between 7" and 12" d.b.
