acoustic foam around tweeter
0 Members and 1 Guest are viewing this topic. Read 1603 times.
tomagardner
« on: 16 Nov 2006, 08:38 pm »
Hi Mike, My 20ish year old 3-way Titan's foam is beginning to deteriorate. What type of foam do you recommend I replace it with? TIA, Tom
Mike Dzurko
Re: acoustic foam around tweeter
« Reply #1 on: 17 Nov 2006, 03:28 pm »
Hello Tom!
The technical description is "non-reticulated, open cell foam".  I would suggest doing a few googles. It is the same thing that most manufacturers use as acoustic foam. If you can find the right thickness you can cut it w/ knife or scissors . . .  some fresh foam ought to last you another 20 years  :D
tomagardner
« Reply #2 on: 17 Nov 2006, 03:34 pm »
Muchas gracias Senor!
They have been relegated to the basement since I got my XLs last year.
Thanks, Tom
