Sharp SD-EX111, can it loop into itself with external DAC?
0 Members and 1 Guest are viewing this topic. Read 2198 times.
Folsom
If I output to a DAC (say I build one :) can it loop back into it?
That or what is a decent extremely cheap transport, or SqueezeBox on sale ha....
Vinnie R.
    • http://www.vinnierossi.com
Re: Sharp SD-EX111, can it loop into itself with external DAC?
« Reply #1 on: 16 Nov 2006, 07:17 pm »
YES, you can use the digital out from the Sharp to an external dac, and feed the output of the external dac into the AUX input of the Sharp  8)
fiveoclockfriday
« Reply #2 on: 16 Nov 2006, 07:31 pm »
I've been wondering this for awhile too. Can anyone comment to there being a noticeable improvement in sound with this method, or does the quality of the AUX input effectively negate the benefits? I would test this, but I don't have a DAC right now. I'd be interested in getting one of the affordable non-os DACs if the consensus is that it improves CD sound from the Sharp.
Vinnie R.
« Reply #3 on: 16 Nov 2006, 07:38 pm »
The output signal of the built-in CD section passes through the same components as the AUX input, so the effect of an external dac will not be negated IMO...
Folsom
« Reply #4 on: 17 Nov 2006, 05:39 pm »
How do the settings work with this? AUX setting for input, but you need the CD to be playing as well? I guess there is some kind of a tweak? Not sure....
Also is it possible to switch to a coaxial digital out by just connecting one before the optical box?
fiveoclockfriday
« Reply #5 on: 20 Nov 2006, 12:35 am »
Destroyer, you bring up a fine point I hadn't thought about. I don't see any concievable way to both play a CD and use the AUX input at the same time. I guess outboard DAC is out for now :(
I did find that there seems to be a similar 'step up' unit out there if you love the functionality and simplicity of the Sharp, but yearn for even higher end sound. It's the Arcam Solo...there's a fairly recent Stereophile review, and a few other individual reviews that praise it. I saw one used on audiogon awhile back for ~ $975, which seemed like a steal.
Vinnie R.
« Reply #6 on: 20 Nov 2006, 12:45 am »
Doh!  :duh:
I forgot that CD must be enabled to play the CD for digital output.
It might work, but you really should design it so the output impedance is 75-ohms.  Buffering might also be a good idea...
Jampot
« Reply #7 on: 20 Nov 2006, 06:24 am »
Just a thought -
Does the Sharp feature a tape loop with monitoring?
If so, play cd, feed dac to tape in and 'monitor' the track being laid down on the non-existant tape.
Jim
Folsom
« Reply #8 on: 20 Nov 2006, 07:45 am »
No tape...
Wow I wish I had a CLUE what I am up to now :duh:
