0 Members and 1 Guest are viewing this topic. Read 4556 times.
I will be feeding a self modded SI T-amp w/Jensen PIOs which power a set of B200s in OB, I also have a set of Augies being fed from a plate amp. I will probably pick up a Promitheus TVC for the volume control duties and I am currently building a 41hz Amp4 that will take over the amplification duties from the SI T-amp Any thoughts?
With regard to the phono preamp, my feeling was that there are probably not that many "good" choices out there given my preamp budget,
...I have the MM version in a system I put together for my 13 year old son.
