Recommend a silver or silver plated very low capacitance IC cable for diy
0 Members and 1 Guest are viewing this topic. Read 987 times.
warnerwh
I like silver plated or silver wire due to the fact it doesn't go bad if it oxidizes. I will use copper also if I like it, just prefer silver after some copper speaker cabling turning green and bulging many moons ago.
If you've made IC cables and know a source to make some good ones please let me know.
I do have some 18 gauge silver plated and teflon insulated wire but it's not shielded. Has anybody had problems using non shielded IC's? My rack has about 8 or 9 electronic pieces so I'm concerned about rfi/emi. If nobody has had much problem maybe I'll make some Kimber clones.
Thanks for any help.
