0 Members and 1 Guest are viewing this topic. Read 5053 times.
Well, once I tore into the 1200 I decided to not replace the tonearm wires. The wires in the tonearm are already pretty thin, maybe 30ga, as compared to the Cardas 33ga wire I have on hand. They may even be as thin as the Cardas wire. I just didn't feel confortable soldering that stuff in such a critical application.
I also have my sights set on a lo mc like the Dynavector 20xl.
Why would you recommend a top notch MM over a LOMC for the SL-1200?
Are there reasons why a good MM is better for this table?
Psychicanimal,Thanks for the response and the link. I'm following the asylum vinyl thread as well.Here's the thing: I have a Scott 222 with a decent MM phono. If I pop for the Denon 103 and the Jolida 9A (a good match according to the comments) I'm in the $700 price range.Would a $600 MM cartridge be a better way to go? How would something like the dynavector 20XH compare to the Denon sonically?
