0 Members and 1 Guest are viewing this topic. Read 4654 times.
That's true; I'd noted that. He's one guy, though, so I was looking for more feedback, and somebody who could talk about the bass performance. He did used the M model too with the 10" woofers. Yeah, most likely this should work out well full-range.If that's true, though, it makes me wonder why so few are doing such things. From what I read, it seems most people throw a lot of solid-state power at these things. Perhaps that's just because high-power SS amps are just much more common.
For me, 93dB is not nearly high enough sensitivity for the 3W or so that 2A3s give. I would not even consider trying that...
8 watts from 300B amp ran out of juice on my 40s (ribbons only) when "pushed" to 80 dB output. Sounded good at low level. The ribbons still sound the best with my push pull over the top 120 tiode watter with full octal tubes for voltage gain and driving. The sound is not loose or bloomy -- just full. Good luck with 2A3 on the '30s.
woodsyi, if you remember, 40w of set power from 6c33c monoblocks did just fine driving your ribbons. these amps are a fantastic value, imo, even when purchased brand new. used, they are even a better deal. aa mine don't have the latest capacitors, vlad of audio mirror is sending me them for install...http://cls.audiogon.com/cgi-bin/cls.pl?ampstube&1167344305
Those are beautiful amps! I considered them at one time but passed because I didn't know anything about them and the deal seemed much too good to be true.They are single-ended? What have you compared them to?
