Industry Circles
Audio by Van Alstine
Mary
High/low filter on Ultra EC...any negative effects?
0 Members and 1 Guest are viewing this topic. Read 1459 times.
Toka
13 Nov 2006, 10:19 pm »
Anyone here use the high/low/rumble (whatever you want to call it) on the Ultra EC preamp? If so, did you note any residual noise or otherwise unwanted effects when it is engaged? I ask because I've seen some nicely-performing external models around for a reasonable price, and since I'm saving money to get the Ultra EC I wanted to know if the built-in option is the best way to go. I don't have any doubts as to Frank's abilities but I've never seen it mentioned anywhere, so I had to ask!
Toka
Re: High/low filter on Ultra EC...any negative effects?
15 Nov 2006, 06:40 pm »
Nobody uses it? Come on, don't be shy.
avahifi
Industry Contributor
ยป
Reply #2 on:
15 Nov 2006, 06:47 pm »
The high/low filter is a simple passive 6 dB per octive filter that will have no sonic effect other than a gentle low and high frequency roll-off, useful for bad source material.
Frank Van Alstine
Toka
Reply #3 on:
15 Nov 2006, 07:08 pm »
Thanks Frank! Sorry for being dense, but does it act similarly to a 'rumble' filter for vinyl playback? As in, cuts off below 20hz or what have you.
Industry Circles
Mary
