0 Members and 1 Guest are viewing this topic. Read 1629 times.
The first product is a device that plugs into either your sound card or into a portable disk player or Walkman. This device buffers the audio output and uses a high quality op amp to provide 6 volt "peak-to-peak" output. This means that the signal will be sufficient to properly drive either a preamp or drive an amplifier directly. Should you choose to use a computer as your DVD and CD player, you do not need a preamp. This device also includes a headphone amplifier so that you can use either your loudspeaker or headphones from a single sound card or portable device. We have not come up with a name for this device yet so we are interested in your ideas. The device will upgrade the signal quality from any sound card and make the signal more compatible with high quality audio preamps and amplifiers.
