Who's making good 32 inches stands?
0 Members and 1 Guest are viewing this topic. Read 1379 times.
unita_logica
  • ustrega!
    • f*** those corporate aliens!
« on: 13 Nov 2006, 03:50 am »
I am in the process of buying a pair of Omega Super 3R's for my office but unfortunately, being a tall guy I need tall stands (around 32 inches). Can anybody recommend a good brand that makes stands that tall?
Bill Baker
    • Musica Bella Audio
Re: Who's making good 32 inches stands?
« Reply #1 on: 13 Nov 2006, 03:57 am »
Try Skylan Stands as they custom make a lot of stands for the Omega speakers. He may be able to accomidate yo on the height you need as well.
http://www.skylanstands.com/
fajimr
« Reply #2 on: 13 Nov 2006, 04:03 am »
I'll second the skylans.. I got a nice pair for my ellis 1801s- they are rock solid, especially after I filled them with sand.  the owner (his name escapes me now) is great to work with and can most likely give you exactly what you need.
unita_logica
  • ustrega!
« Reply #3 on: 13 Nov 2006, 04:06 am »
Thanks for the quick reply to both of you. I had looked at Skylan's website but the tallest (non-custom) speaker they make is 28" tall.
My preference would be for a non-custom solution to contain the cost.
Any other brand beside Skylan?
fajimr
« Reply #4 on: 13 Nov 2006, 04:32 am »
drop them an e-mail to ask about the price... you just might be surprised.  then again, you might not (there is a threaded rod that attaches the top plate to the bottom so I imagine that is where the custom issue might come in here if he has to source out a different sized rod)...
good luck- sorry I can't offer other solutions jim
WEEZ
« Reply #5 on: 13 Nov 2006, 03:31 pm »
I believe that Noel at Skylan will make any height you need....
worth a phone call.
WEEZ
Bob Reynolds
« Reply #6 on: 13 Nov 2006, 09:22 pm »
Sound Anchor Adjustable Studio stands. http://www.soundanchors.com/ They are not inexpensive, but are some of the best stands made and will last a lifetime.
Charles Calkins
« Reply #7 on: 13 Nov 2006, 09:50 pm »
You could buy the 28" Skylan speaker stands and have a good buddy woodworker build a 4" tall box to sit them on and get the 32" height you're looking for. You could even fill the boxes with a heavy material like sand or something for better stability.
 Me. I'm cheap!! I build all my audio racks and cabinets out of Oak. I have to when I find certain sizes that I need are not available.
                              Cheers
                              Charlie
unita_logica
  • ustrega!
« Reply #8 on: 13 Nov 2006, 11:32 pm »
I just sent an email to Skylan, after all it's always worth asking... let's see what he says. :)
unita_logica
  • ustrega!
« Reply #9 on: 13 Nov 2006, 11:44 pm »
That's a good idea. I actually was considering that because I have the option to buy the Skylan 24" stands for a discounted price with the speakers from Jacob of WitchDoctorAudio (great guy), who also suggested the same thing.
Me. I'm cheap!!
Eh, me too too... Maybe it's time to learn some wood working skills!  :wink:
Charles Calkins
« Reply #10 on: 13 Nov 2006, 11:57 pm »
Yo Bro.!!!
 I see you live in Oakland Ca. I live in Martinez Ca. If you need a woodworker I'd be more than happy to help you.
                                      Cheers
                                    Charlie
unita_logica
  • ustrega!
« Reply #11 on: 14 Nov 2006, 10:22 am »
Yo Bro.!!!
Hey, thanks for the offer, check PMs...  :wink:
If I go the "foot boxes" way, how would the anchoring work? The 24" Skylan's have pretty long spikes that will hardly penetrate the wood... should I get smaller spikes or even remove them? And do I need spikes underneath the boxes too? :?  Just thinking out loud at the best sounding solution ...   :scratch:
