sp-2 sound issue
0 Members and 1 Guest are viewing this topic. Read 9856 times.
redsierra
Re: sp-2 sound issue
« Reply #20 on: 16 Dec 2006, 01:29 am »
Well...bought my Toshiba HD XA1 and I still get the "snapping" when pressing some function on the player.
This is really leading me to believe that it is the processor.  I have tried the mute settings from .5 to 1.5.  You can clearly hear it snapping and then the mute function kick in.  I also have the digital force on as well.
It drives me crazy!
MOZ
« Reply #21 on: 18 Dec 2006, 05:05 pm »
It drives me crazy!
I got used to it  :icon_lol: but i have to try the new software upgrade (the august one) !
redsierra
« Reply #22 on: 18 Dec 2006, 05:39 pm »
The new software didnt change anything.
I still get it.  You are better natured than I am then.  It absolutely ANNOYS and embarasses me!
Dwight
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #23 on: 20 Dec 2006, 11:41 am »
Dwight
Dwight,
If I recall doesn't the Vanderstein Sub have to be connected is a specific way to intigrate with the mains - grounds are tied together?
james
redsierra
« Reply #24 on: 10 Jan 2007, 12:41 am »
James, I had HDMI "handshake" issues with the 1st Generation Toshiba HD A1 HD DVD player, so it went back.  I now have the 2nd Generation HD A2.  Halaluya...no more snapping!  It is funny, becuase I still kind of wince every time I go to press a button on the remote.  I guess I will get used to a properly functioning unit sooner or later.
Dwight
« Reply #25 on: 10 Jan 2007, 05:24 am »
Dwight
Great to hear Dwight -thanks for the update.
james
flom
« Reply #26 on: 20 Apr 2008, 07:26 pm »
Do you know if it is possible to bypass SPV searcharging at SP2 Startup?
The generated issue is the when I use a universal remote control (harmony1000) : after boot, the remote ctrl is not able to push the SP2 appropriate input and I have to "manually" select my activities (DVD/CD...). This was not the case with SP1.7...
I saw SP codes : 030/048 that are not operant. Could you please help? I don't use any SPV.
Cheers
Fabien
« Reply #27 on: 21 Apr 2008, 12:47 am »
Cheers
Fabien
Hi Fabien,
I think it is possible to bypass the SPV startup- I will check with engineering tomorrow.
james
flom
« Reply #28 on: 21 Apr 2008, 07:21 am »
Hello James, sounds great!
Fabien
flom
« Reply #29 on: 22 Apr 2008, 02:06 pm »
Cheers
Fabien
Hi Fabien,
james
Hi James, no news on this option?
Cheers
Fabien
« Reply #30 on: 22 Apr 2008, 02:45 pm »
Cheers
Fabien
Hi Fabien,
james
Cheers
Fabien
Hi Fabien,
Asked our software guy and he is going to see if he can alter the code.
james
flom
« Reply #31 on: 22 Apr 2008, 02:51 pm »
you mean by alter, the fact that the person should provide another fw?
« Reply #32 on: 22 Apr 2008, 03:14 pm »
I mean - delete the code that tells the SP2 to look for the SPV-1.
james
brucek
« Reply #33 on: 22 Apr 2008, 10:22 pm »
Why not modify the firmware to allow a customer to defeat or enable the feature (using a code).
That way everyone would have the option to shut it off, and the SP2 would boot faster.
Lots of unused codes available.....
brucek
