strata mini vs ob7
0 Members and 1 Guest are viewing this topic. Read 2135 times.
rjneill
strata mini vs ob7
« on: 10 Nov 2006, 11:17 pm »
I'm sure Danny's fingerprints are all over both speakers so I'd like to see if he has an opinion on both new speakers or anyone else that may have heard these similar priced speakers...Thanks
« Last Edit: 10 Nov 2006, 11:30 pm by rjneill »
Danny Richie
Re: strata mini vs ob7
« Reply #1 on: 10 Nov 2006, 11:38 pm »
If you enjoy building a kit and have the ability to build your own boxes then going the kit route will give you more for your money every time.
The OB-7 has a few performance advantages in that the use of the open baffle gives you a more open and airy presentation, especially through the vocal region. It's use of multiple drivers also lowers distortion and allows for greater output levels (91 db sensitivity compared to 86 or so with the Mini). The OB-7 also uses a larger 12" powered woofer. It has a much great power handling ability too. I'd clearly have to give the overall performance edge to the OB-7.
However, the Mini does nothing wrong and everything well and does so for a very good turn key price that makes it tough to beat. No fully assembled speaker in its price range is going to touch it. The planar magnetic drivers give it resolution and detail levels that easily match the OB-7. It looks beautiful too.
It just really depends on what you're looking for and the price range that you are looking in as to which route you might favor.
3beanlimit
« Reply #2 on: 11 Nov 2006, 04:22 am »
I'm more interested in your thoughts on the mini vs the LS-6 or LS-9's.
I almost bit the bullet on the minis.  In fact I was on the order list and decided to back out.  I really need a speaker that can do a semi double duty for both stereo and HT.   I don't have a choice and was talked out of the mini by others.
Danny Richie
« Reply #3 on: 11 Nov 2006, 04:36 am »
The Mini is a fine speaker. I am quite proud of it, but it is no LS-6 or LS-9.
3beanlimit
« Reply #4 on: 11 Nov 2006, 05:28 am »
*Rubs hands and starts caculating MDF needed for two boxes.*
Hey about them LS-x plans...who's idea was it to use decimals for measurements?  My tape measure only speaks fractions! lol
« Last Edit: 11 Nov 2006, 10:50 pm by 3beanlimit »
Joey Skinner
« Reply #5 on: 11 Nov 2006, 03:07 pm »
Someone who needs accuracy to the nearest 10,000th of an inch! :D
