0 Members and 1 Guest are viewing this topic. Read 4854 times.
1. In general I prefer a live rather that dead acoustic space, as a slowly-decaying reverberant field adds richness and livelines to the presentation. Looks like you're off to a good start there.2. Do you have any slap-echo? If so, a tapestry or two along the back wall might help, or along one of the side walls, depending on where it's coming from. You only have to treat one of each pair of opposing reflective surfaces. A throw rug on the floor to take the edge off the floor bounce might be beneficial too. But don't overdo it - too much absorption will suck the life out of the sound.3. I don't see sidewall reflections as a problem because their path length delay is long enough that they're unlikely to be detrimental. 4. With a large, fairly reverberant room, the power response of the loudspeakers will play a dominant role in their perceived tonal balance. What kind of speakers do you have? Their power response might end up being a significant issue. If we know the on-axis response and driver sizes and types and ballpark crossover frequencies we can make some educated guesses about the power response. Even better, maybe we can find off-axis frequency response curves somewhere on the internet.5. Are you looking to optimize for best possible sound right in the center of the sweet spot, or do you want good sound throughout the room (even well off to the side of the speakers)? Obviously we'd like both, but assuming you have to lean one way or the other...
Quote from: Christof on 6 Nov 2006, 01:54 amWhat's wrong with the boombox? Is this your work/studio or domestic/living quarter? In other words, what type of decor are you going for?
I'd set up on the short wall.
I would, however, build diffusors with good natural wood if I had the kind of wherewithall with carpentry like you do. Do some research and you can get quadratic formulars with well depth sequence and size for the diffusors. This could be really good.
I'd probably add that he could suspend some creatively designed diffusion on the ceiling as well that would be in total character with his design theme and take it up to a serious level of room treatment, comparable to studio control rooms.
Nice work so far Christof......(older photo)It's gonna look really nice when its complete........
