Hemptone subwoofer?
0 Members and 1 Guest are viewing this topic. Read 4059 times.
rajacat
  • Washington State
Hemptone subwoofer?
« on: 4 Nov 2006, 01:08 am »
Louis. How about designing a Hemptone subwoofer that can go very low (20Hz), move some air and mate well with the Omega lineup?
Raja
Brad
Re: Hemptone subwoofer?
« Reply #1 on: 4 Nov 2006, 02:14 am »
Tone tubby makes some nice 12" hemp drivers......c'mon Louis..... :guitar:
Vinnie R.
    • http://www.vinnierossi.com
« Reply #2 on: 4 Nov 2006, 02:20 am »
Hey guys,
I think Louis is looking into these.
That would be sweet!
-Vinnie
Louis O
« Reply #3 on: 15 Nov 2006, 01:09 am »
I just got in a set of 8" sub drivers with TT cones. They are overbuilt and I will try them out. I was also leaning toward a 12" pro driver. This won't be a true sub , but will have some slam and will be pretty fast.
Thanks again,
Louis
JoshK
« Reply #4 on: 15 Nov 2006, 01:14 am »
Raja
Not easy to do.  You know the triangle rule?  In the corners of a triangle you have efficiency, small size, deep bass...pick any two and you can't have the third.  In order to 'keep up' I am assuming you need some efficiency...if you want 20hz with that you will need a *HUGE* sub.  If you only want extention but not flat to 20hz then that makes it a bit less huge, but still quite large.
kenscott30
« Reply #5 on: 15 Nov 2006, 03:16 am »
rajacat
  • Washington State
« Reply #6 on: 15 Nov 2006, 03:35 am »
Raja
I guess you could go with a 12" servo sub like this...http://www.rythmikaudio.com/servo_product.htm
Smooth response to 20hz and below. aa
Raja
Louis O
« Reply #7 on: 23 Nov 2006, 01:14 am »
Hi,
JoshK is right and have very low bass output it will need a lot of box. Servos do work and a Rajacat is right as well. For me I would be more interested in making a bass augmenter that will blend with the speakers which is also very hard to do. The main problem is getting the right electronics made and this costs a lot. At this stage I would rather spend it on the speakers.
Thanks again,
Louis
