Requesting PSW recommendation for Mission 707 Speakers
0 Members and 1 Guest are viewing this topic. Read 3598 times.
John Bauder
I picked up these speakers on ebay cheap.  I was not able to find any reviews or specs but at the price I went ahead.  They are being used with my second sytem in the bedroom.  NAD 3020 integrated amp, Pioneer PL-514 TT, Sony CDP C 245.  I really like the sound except for a real lack of bass.
Later I was able to get the following specs from Mission:
TYPE: 2 way inverted drive, reflex loaded speaker
DRIVE UNITS:
     Vifa 210 mm LF unit, C20 8 ohm [similar to the one used in the M-762]
     Vifa 19 mm HF Polymer Dome, D19  [similar to the one used in the M-761]
FREQ. RESPONSE:  50Hz-20Khz  +/-3dB
FREQ RANGE:  30Hz-20Khz
SENSITIVITY: SPL 1M/2.83v   91dB
X-OVER FREQ:  2.7Khz
It seems to me I should be getting better bass from them but I'm not.  Can anyone recommend a low price PSW for this set up?  I don't plan to upgrade so don't need one that will way outperform the rest of the equipment.
« Reply #1 on: 27 Jun 2003, 12:57 am »
Adire Rava.  Very musical indeed.  $400 with amp and crossover built in.  Will go quite loud and (and stay clean) if you want it to.
BikeWNC
« Reply #2 on: 27 Jun 2003, 12:59 am »
Check out this thread from the Critics Circle.
http://www.audiocircle.com/index.php?topic=1948
Andy
John Bauder
« Reply #3 on: 3 Jul 2003, 01:02 am »
Thanks to both of you.  I picked up a used Yamaha YST-SW205 on ebay and should have it any day.
BikeWNC
« Reply #4 on: 3 Jul 2003, 01:35 am »
John,
I'd like to hear what you think of it when you get the chance.
Andy
